Attached you´ll find the last official release of the ISO-MME database.
This database contains all codes and figures and is able to generate the official RED B and C Documents.
it is splitted in several documents. After copying it you have to set the path to the backend during the first startup. The path to the figures has to be set unter "System-Figures".
Please be so kind and contact me for questions or if you find any data or software bugs.
This software can also be downloaded at ISO standards website
Database release : 2.4
Data release 1.5
ISo MME Database
- Location: Delphi Deutschland GmbH; Delphiplatz 1; 42119 Wuppertal, Germany; Tel.:+49(0)202-291-3325
ISo MME Database
- ISO TS13499 RED BC MMÉ DB V15 Figures Interior_Airbag.zip
- Figures Interior Airbag
- (919.77 KiB) Downloaded 651 times
- ISO TS13499 RED BC MMÉ DB V15 Figures Vehicle.zip
- Figures Vehicle
- (1.85 MiB) Downloaded 683 times
- ISO TS13499 RED BC MMÉ DB V15 Figures Child.zip
- Figures Child
- (458.03 KiB) Downloaded 625 times
- ISO TS13499 RED BC MMÉ DB V15 Figures Side.zip
- Figures Side
- (2.28 MiB) Downloaded 683 times
- ISO TS13499 RED BC MMÉ DB V15 Figures Frontal_Rear_Pedestrian.zip
- Figures Frontal Rear Pedestrian
- (943.28 KiB) Downloaded 685 times
- ISO TS13499 RED BC MMÉ DB V15 Backend.zip
- Database Backend
- (216.9 KiB) Downloaded 673 times
- ISO TS13499 RED BC MMÉ DB V24 Frontend.zip
- Database Frontend
- (695.36 KiB) Downloaded 655 times
Olaf Schaar
Lead Test Engineer
Electronics & Safety Systems
Tel.: +49(0)202-291-3325
Fax.: +49(0)202-291-3419
Mobile: +49(0)151-18223791
eMail : olaf.schaar@delphi.com
Customer Technology Center Wuppertal
Lead Test Engineer
ISO MME Database - Addition
The database frontend ISO-MME.mdb doesn't work on our computers.
With Olaf's help I've created the frontend ISO-MME_XP.mdb.
If someone has problems with the original database he should try this version.
- ISO TS13499 RED BC MME DB V24 Frontend Alternative.zip
- Alternative database frontend
- (731.61 KiB) Downloaded 668 times
