New FineLocations 3 for deformable elements
for the static data measurement and simulation of side and frontal impact tests
it would be fine to distinguish between the various deformable elements.
Analogue to the belt zones, pedestrian impactors and airbags
I propose the following codes for the FineLocation 3:
  • DO - Deformable element for Offset tests (frontal impact)
    DI - Deformable element according IIHS test protocol (side impact)
    DN - Deformable element according NHTSA test protocol (side impact)
    DE - Deformable element EuroNCAP Advanced2000 (side impact)
    DA - Deformable element AEMDB (side impact)
This FL3 codes should be used for scan data of deformable barriers and
for measurements in the simulation environment.
Please have in mind that in MME 2.0 we try to describe objects
which should be named with the relevant parts of the Channel Code.
Peter Derpmann-Hagenström
Re: New FineLocations 3 for deformable elements
Discussed 2014-04-02: in principle, this is agreed, subject to a suitable figure.
