New physical dimension MF for 'Mass Flow'
Posted: Fri Mar 08, 2019 12:19 pm
by gieschef
To describe mass flows we need to describe those channels by a new physical Dimension. Even if currently those channels are only calculated by mathematical Simulation up to now, we would like to be consistent in exchenging datasets via MME.
Proposal would be 'MF', our used unit for this would be 'kg/s'
Re: New physical dimension MF for 'Mass Flow'
Posted: Mon Mar 11, 2019 10:40 am
Dear Frank,
your proposal will not interfere with the current codes for physical dimensions.
I have prepared the proposal for discussion and decision making at the next meeting:
- MassFlow_PD-Proposal.png (5.71 KiB) Viewed 4917 times
Posted: Thu Apr 11, 2019 2:18 pm
added to database with the name: "Mass Flow Rate" (2019-04-10; 1.6.2p3):
- Mass_Volume_Flow Rate.png (5.75 KiB) Viewed 4860 times
Posted: Wed Jul 17, 2019 9:29 am
Topic closed during NetMeeting 2019-07-17
