To describe volume flows of gases or liquids we Need to describe those measurements by a new physical Dimension.
Proposal would be 'VF', our used unit for this would be 'l/min', SI unit is propably 'm*m*m/s'
New physical dimension VF for 'Volume Flow'
Re: New physical dimension VF for 'Volume Flow'
Hi Frank,
seems you are in a "flow" today
Same as for your mass flow proposal:
- No interference with existing codes.
- Proposal prepared for discussion and decision making.
added to database with the name: "Volume Flow Rate" (2019-04-10; 1.6.2p3):
Topic closed during NetMeeting 2019-07-17
