due to user request please find attached the preliminary code database including the QB-Dummy as discussed in:
viewtopic.php?f=38&t=569&p=1015#p1015
The complete database will follow soon.
Ingo Wülfing
on behalf of Dirk Vetter
Preliminary MME Code Database 1.6 Rev 2 Proposal 3
wuelfing
- Company: IAT mbH, Berlin, Germany
- mme_code_162p3_preliminary.zip
- (509.28 KiB) Downloaded 1381 times
Oliver Schnaus
- Company: Kistler Instrumente GmbH
Re: Preliminary MME Code Database 1.6 Rev 2 Proposal 3
I checked the 1.6.2rc1 distributed by Dirk Vetter on the MDVFS in Oct 1st 2019 and observed the following inconsistencies in the MME_POSSIBLE_CHANNELS:
Correction of direction:
909;"S2 Dummy";"?";"?";"FARM";"RI";"00";"S2";"MO";"Z";"?";"Forearm Right Moment Z";"Unterarmmoment rechts Z";1;14.10.1999 00:00:00;;1;"19000";;"S2";;;
Duplicates:
8701;"Q1 Dummy";"?";"?";"ABDO";"LE";"00";"Q1";"PR";"0";"?";"Abdomen Left Pressure";"Abdomen Druck links";44;30.11.2015 00:00:00;"optional measurement";0;"18100";;"Q1";;;
8702;"Q1 Dummy";"?";"?";"ABDO";"RI";"00";"Q1";"PR";"0";"?";"Abdomen Right Pressure";"Abdomen Druck rechts";44;30.11.2015 00:00:00;"optional measurement";0;"18100";;"Q1";;;
8703;"Q2 Dummy";"?";"?";"ABDO";"LE";"00";"Q2";"PR";"0";"?";"Abdomen Left Pressure";"Abdomen Druck links";44;30.11.2015 00:00:00;"optional measurement";0;"18200";;"Q2";;;
8704;"Q2 Dummy";"?";"?";"ABDO";"RI";"00";"Q2";"PR";"0";"?";"Abdomen Right Pressure";"Abdomen Druck rechts";44;30.11.2015 00:00:00;"optional measurement";0;"18200";;"Q2";;;
8705;"Q3 Dummy";"?";"?";"ABDO";"LE";"00";"Q3";"PR";"0";"?";"Abdomen Left Pressure";"Abdomen Druck links";44;30.11.2015 00:00:00;"optional measurement";0;"18300";;"Q3";;;
8706;"Q3 Dummy";"?";"?";"ABDO";"RI";"00";"Q3";"PR";"0";"?";"Abdomen Right Pressure";"Abdomen Druck rechts";44;30.11.2015 00:00:00;"optional measurement";0;"18300";;"Q3";;;
8707;"Q6 Dummy";"?";"?";"ABDO";"LE";"00";"Q6";"PR";"0";"?";"Abdomen Left Pressure";"Abdomen Druck links";44;30.11.2015 00:00:00;"optional measurement";0;"18600";;"Q6";;;
8708;"Q6 Dummy";"?";"?";"ABDO";"RI";"00";"Q6";"PR";"0";"?";"Abdomen Right Pressure";"Abdomen Druck rechts";44;30.11.2015 00:00:00;"optional measurement";0;"18600";;"Q6";;;
8709;"QA Dummy";"?";"?";"ABDO";"LE";"00";"QA";"PR";"0";"?";"Abdomen Left Pressure";"Abdomen Druck links";44;30.11.2015 00:00:00;"optional measurement";0;"18900";;"Q10";;;
8710;"QA Dummy";"?";"?";"ABDO";"RI";"00";"QA";"PR";"0";"?";"Abdomen Right Pressure";"Abdomen Druck rechts";44;30.11.2015 00:00:00;"optional measurement";0;"18900";;"Q10";;;
8474;"QA Dummy";"?";"?";"THSP";"01";"LE";"QA";"AC";"Y";"?";"T1 Acceleration left Y";"T1 Beschleunigung links Y";44;15.4.2015 00:00:00;"for dummy certification purposes; shoulder test";0;"18900";;"Q10";;;
8475;"QA Dummy";"?";"?";"THSP";"01";"RI";"QA";"AC";"Y";"?";"T1 Acceleration right Y";"T1 Beschleunigung rechts Y";44;15.4.2015 00:00:00;"for dummy certification purposes; shoulder test";0;"18900";;"Q10";;;
9415;"QB Dummy";"?";"?";"ABDO";"LE";"00";"QB";"PR";"0";"?";"Abdomen Left Pressure";"Abdomen Druck links";47;10.4.2019 00:00:00;"optional measurement";0;"18950";;"Q10";;;
9416;"QB Dummy";"?";"?";"ABDO";"RI";"00";"QB";"PR";"0";"?";"Abdomen Right Pressure";"Abdomen Druck rechts";47;10.4.2019 00:00:00;"optional measurement";0;"18950";;"Q10";;;
9407;"QB Dummy";"?";"?";"THSP";"01";"LE";"QB";"AC";"Y";"?";"T1 Acceleration left Y";"T1 Beschleunigung links Y";47;10.4.2019 00:00:00;"for dummy certification purposes; shoulder test";0;"18950";;"Q10";;;
9408;"QB Dummy";"?";"?";"THSP";"01";"RI";"QB";"AC";"Y";"?";"T1 Acceleration right Y";"T1 Beschleunigung rechts Y";47;10.4.2019 00:00:00;"for dummy certification purposes; shoulder test";0;"18950";;"Q10";;;
9209;"YA Dummy";"?";"?";"SPIN";"UP";"00";"YA";"AC";"X";"?";"Spine Upper Acceleration X";"Wirbelsäulenbeschleunigung oben X";47;10.4.2019 00:00:00;;0;"24500";;"YA";;;
Best Regards,
Oliver Schnaus
Duplicates:
Best Regards,
Oliver Schnaus
Dear Oliver,
thanks for your verification.
a) The Abdominal pressure sensors for the Q-Dummies has been overlooked and introduced twice.
I have removed now the more recent versions in the PC list.
b) THSP01 LE/RI QA ACY: doubled entry removed
c) THSP01 LE/RI QB ACY: doubled entry removed
d) SPINUP00YAACX: changed double entry to SPINLO00YAACX
e) FARMRI00S2MOY: changed double entry to FARMRI00S2MOZ
Hope we are now clean with the coding.
Changes will be available in the 1.6.2rc2 after the next status meeting on 2019-10-30.
If you have an urgend need of a copy of the backend db before, please let me know.
p.s. Discussion will be continued in:
