Channelcodes for SUFEHM channels
gieschef
Company: ZF Automotive Germany GmbH
Post by gieschef »
When the calculated channels from SUFEHM are attached to a dataset we need special ISO-codes for those ( two ) channels.
To Keep them associated with the HEAD we propose to Keep Mainlocation HEAD and the dummytype in FL3 for them.
for example :
S1HEADVMSTTHPR0S
S1HEADSUF0TH000S
or, in more general :
??HEADVMST??PR0S
??HEADSUF0??000S
Not so nice with the combined FL1/FL2, but readable for the user ...
Looking forward on comments,
best regards,
Frank
Re: Channelcodes for SUFEHM channels
Dear Frank,
a while ago I have started to prepare a coding for RED E.
It is "work in progress" (ignore the word BRIC in the snapshot below), but may useful for the discussion:
I would like to move this discussion to the RED E board.
@Paul: Is this possible?
please post further replies to this topic here:
viewtopic.php?f=104&t=596
MainLocation should be HEAD and the channels:
??HEADVM00??SR0S (van mises stress)
??HEADSM00??000S (sufehm criterion)
I have added to the database 1.6.2:
In Fine Location 1 table:
2020-02-05 20_03_59-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_02_Versi.png
2020-02-05 20_03_59-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_02_Versi.png (31.77 KiB) Viewed 52221 times
In the Possible Channels table:
2020-02-05 20_11_09-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_02_Versi.png
2020-02-05 20_11_09-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_02_Versi.png (30.46 KiB) Viewed 52221 times
Sorry for the small images, but they are shrinked by the system.
So please find the two images also in the attached archive.
SUFEHM Codes.zip
(53.88 KiB) Downloaded 1592 times
Sebastian Rings
Post by Sebastian Rings »
The "stress" (VM) is named after Richard von Mises. Therefore, could you please correct in the TEXT_L1 and TEXT_L2 "Van" to "von"?
Sebastian
Dear Sebastian,
thanks for the hint.
I have changed this in the FL1 and the Possible Channels table.
Closed during online meeting 20200401
