we need a new main location for the towing lug.
It is used in Towing/Pressure Tests at the front and rear end of the vehicle -> Positions 1,2,3,7,8,9
Measured physical units are DS and FO.
Proposals for the naming:
TOLU - towing lug - Abschleppoese
TEYE - towing eye - Abschleppoese
Best Regards
New Main Location for Towing Lug
- Example for position 3
- TowingLug.jpg (27.91 KiB) Viewed 27669 times
Re: New Main Location for Towing Lug
Dear Peter,
I reviewed the database:
- no interference or similarities to existing codes
- "TEYE" sounds more self descriptive (my opinion), but both sounds good in general
- Direction is in both cases (DS, FO) needed as "0" or "X","Y","Z"?
- Should we define the codes in the Possible Channels table with additional long name information?
?1TEYE??????DS0?; towing eye front left; Abschleppoese vorne links
?2TEYE??????DS0?; towing eye front middle; Abschleppoese vorne Mitte
?9TEYE??????DS0?; towing eye rear right; Abschleppoese hinten rechtsKind regards,
added to the database 1.6.3p1:
Main location: Possible channels: Kind regards,
Update of figure required.
