New Main Location for Towing Lug
we need a new main location for the towing lug.
It is used in Towing/Pressure Tests at the front and rear end of the vehicle -> Positions 1,2,3,7,8,9
Measured physical units are DS and FO.
Proposals for the naming:
TOLU - towing lug - Abschleppoese
TEYE - towing eye - Abschleppoese
Best Regards
Example for position 3
Re: New Main Location for Towing Lug
Dear Peter,
I reviewed the database:
  • no interference or similarities to existing codes
Codes with T.png (6.45 KiB) Viewed 27639 times
  • "TEYE" sounds more self descriptive (my opinion), but both sounds good in general :-)
Questions:
  • Direction is in both cases (DS, FO) needed as "0" or "X","Y","Z"?
  • Should we define the codes in the Possible Channels table with additional long name information?
?1TEYE??????DS0?; towing eye front left;   Abschleppoese vorne links
?2TEYE??????DS0?; towing eye front middle; Abschleppoese vorne Mitte
?9TEYE??????DS0?; towing eye rear right;  Abschleppoese hinten rechts
added to the database 1.6.3p1:
Main location:
2021-03-10 17_55_50-Window.png (2.23 KiB) Viewed 27075 times
Possible channels:
2021-03-10 17_54_20-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versi.png
2021-03-10 17_54_20-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versi.png (8.95 KiB) Viewed 27075 times
Klaas
Company: measX
Post by Klaas »
Update of figure required.
