Example Datasets
This technical specification defines a data format to exchange data that is relevant for exchanging and using measurement equipment between calibration service providers, laboratories and requestors in vehicle safety testing.
You will find here additional documents for the usage and implementation of the standard (XSD, demo data).
The ISO TS 23520 base document is available via the ISO organisation.
Moderator: AK-ISO-MME
gieschef
Company: ZF Automotive Germany GmbH
Example Datasets
Post by gieschef »
Attached a Zip-file with three EQX files and a quick description of what is contained.
Please feel free to post your feedback and possible challenges.
EQX_sampledata.zip
(88.27 KiB) Downloaded 1313 times
Kate
Company: DTS
Re: Example Datasets
Post by Kate »
Can you help please with how to define a 3D IRTRACC with radius calibration using the v1.6 XSD ? The problem is I do not see any definition of the equation for when the units are "mm" only mV or LSB.
Attached is my formula for the IRTRACC Radius Cal ...
Thank you
IRTRACC Radius Cal Formula with coeffs.png (239.96 KiB) Viewed 51522 times
Oliver Schnaus
Company: Kistler Instrumente GmbH
Post by Oliver Schnaus »
The Zero-Int [mm] can be divided by the Cal.factor [mm/V lin] to obtain the Zero-Int [V lin]. Multiply with 1000 to get it in [mV lin], which is required in Sensitivity3 of the EQX.
The sensitivity needs to be calculated from "mm/V lin" to "mV lin/mm" for the Sensitivity element of the EQX.
Return to “Documents and RED (XSD, demo data)”
