Airbag Coding
Airbag Coding
there is a request and proposal from BMW to discuss and document a more complete coding approach for the
measurement channels related to Airbags. You will find a proposal attached.
We will have a discussion in the next task force meeting and hope for feedback, experiences and advices from other users.
2023-08-09_Proposal_for_ISO_codes_airbag.xlsx
(19.63 KiB) Downloaded 937 times
Re: Airbag Coding
Dear colleages,
please find here, as reference, the actually available figures for Airbag Coding:
ISOMME-Airbag-Codes-2020.pdf
(28.31 KiB) Downloaded 904 times
Re: Airbag Coding
Dear All,
after the meeting I have received the final presentation for the VDA Airbag Coding approach.
Please find a copy here attached.
2025-06-06_Proposal_for_ISO_codes_airbag_v11.pdf
(1.05 MiB) Downloaded 860 times
Re: Airbag Coding
in the database I have now prepared the following extensions for the ew Airbag coding:
Extensions for FL1:
2025-06-06 13_26_14-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png
2025-06-06 13_26_14-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png (28.89 KiB) Viewed 15793 times
Changes for FL2:
2025-06-06 14_29_28-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png
2025-06-06 14_29_28-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png (5.71 KiB) Viewed 15793 times
Extensions for Directions:
2025-06-06 09_54_23-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png
2025-06-06 09_54_23-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png (10.17 KiB) Viewed 15793 times
Please report back to me if the translations are not matching the intended code part.
Re: Airbag Coding
Dear All,
I have added the codes for "Airbag" and "AirbagSim" to the current database proposal vor 1.6.3/1.7,
I needed to add also the new code part "AV" for FL3:
2025-07-22 17_16_28-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png
2025-07-22 17_16_28-Access - mme_code _ Database- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versio.png (5.57 KiB) Viewed 14879 times
to comply to all coding proposals.
