Hello Everyone,
as discussed in the meeting, Adriano Palao from Euro NCAP proposed an update of the naming convention for Euro NCAP tests.
He kindly shared his thoughts with us in search for input. I put his presentation with his thoughts here for reviev and lively discussion.
Euro NCAP Draft for Naming convention
- DRAFT TB 021 Naming Convention Proposal - V0.1.pdf
- (1.29 MiB) Downloaded 1202 times
Re: Euro NCAP Draft for Naming convention
here are some ideas and remarks to the propoal of Euro NCAP to integarte the attibutes in ISO13499 RED F.
There are some new proposals for MME attributes:
But also differences in naming which should be harmonized:
Please see the slides or teh discussion in TF MME active safety for details:
Kind regards
.Nom. Heading test object X
.Pos. Offset test object X
.Striking point TO X
.Overlap VUT to TO XCode: Select all
.Dimension of test object X
.Dimensions test object XKind regards
Dear Mr. Washausen,
I would agree that an abbreviation for "test object" will improve the readability of the descriptors.
Leaving more space for relevant words and characters.
I would propose to use "TOB" as abbreviation instead of TO.
here is an update of to TOB instead of TO.
I have also added more details in definition of ".Nominal Heading TOB X".
