There is a request from Humanetics to step forward with the coding list of the THOR AV.
In the topic: https://www.iso-mme.org/forum/viewtopic.php?p=1249
we defined the base FL3 code for this kind of dummies.
For the specific variant of Humanetics a channel list and may figures are desired to
support the standardisation in the channel naming for this variant.
Attached you will find a list of the available instrumentation for the THOR AV.
Figures for THOR AV
Re: Figures for THOR AV
Can you confirm that the AV will use TV as the fine location 3? I have started the copy of TH and will update it with the specific sensors.
Attached is a draft for the THOR AV Figure
- ISO-TV_20250305.pdf
- (149.57 KiB) Downloaded 589 times
