New Codes for Quaternions
exchanging angle information needs some additional information about the order of rotation and the usage
of fix or rotating axes. This problem can be avoided by using 4 quaternions instead of 9 elements of a rotation matrix.
These quaternions have the unit [1] and are named qw, qx, qy, qz.
Therefor I propose the new Physical Dimension QU with the text "Quaternion" and the default unit "1".
To distinguish between the 4 quaternions we can use the Directions X, Y, Z and need
a new Direction W.
Paul Wellicome
Company: HORIBA MIRA Ltd
Re: New Codes for Quaternions
Post by Paul Wellicome »
proposed: to adopt QU, but to use X,Y,Z and 0.
All agreed. OLM 30 Jul 2009.
Physical Dimension "QU" added in DB 1.6p2.
