BioRID - 20130305 revision
Paul Wellicome
Company: HORIBA MIRA Ltd
Post by Paul Wellicome »
This is a draft copy of the BioRID figure.
In the light of the Excel workbook circulated after the on-line meeting of 27 February 2013, I have moved some channels to the additional instrumentation pages. This includes all Y-acceleration channels at C4, T1, T8, and L1, Head angular velocity, Neck Lower 6-axis.
I have added a note to the effect that the contact event for the skull cap is denoted HERE000000EV.
I have added a note allowing C4, T1, T8, and L1 accelerations and angular velocities to be denoted LE or RI, if there is a pair mounted either side of the spine.
Question: The documentation from Humanetics refers to the forces and moments at the thoracic spine T1 position. We have denoted that as NECK LO rather than the THSP 01. I realise that this is correct for Hybrid III ATDs, but which should we use for BR?
ISO-BR_20130305.pdf
ISO-BR 20130305, PDF, 4 pages
(909.71 KiB) Downloaded 1188 times
Paul.
Return to “BioRID (BR)”
