Hello colleagues,
please find the first set of figures for chest deflection measurements.
It is a summary of systems for frontal and side impact across all dummy types.
Chest Deflection - 20130826 revision
- ISO-CHST_20130826.pdf
- pdf-version
- (99.39 KiB) Downloaded 1860 times
Chest Deflection - 20130827 revision
Hello colleagues,
by your quick response I updated the figures.
There are some small editorial changes and an addition to the IR-TRACC channels.
If the chest deflection is calculated by a software the result channels should have the 'Data source' calculated.
If the result channels are directly obtained by a hardware linearisation their 'Data source' should be transducer
and the 'Data status' linearised data.
- ISO-CHST_20130827.pdf
- updated pdf-version
- (221.25 KiB) Downloaded 1784 times
