Chest Deflection - 20131011 revision
Channel codes for chest deflection measurement
after the discussion at the last German AK3 I have updated the proposal of the chest deflection figures.
The deflection channels for all dummies of the Hybrid III - and the Q-Family should have the MainLocation CHST.
If the chest deflection is calculated by a software the result channels should have the 'Data source' calculated.
If the result channels are directly obtained by the hardware (including a linearisation) their 'Data source' should be transducer .
All (?) displacement channels of IR-TRACCs coming directly from the transducer should have the direction 0.
ISO_CHST_16R1_20131011.pdf
updated pdf-version
(609.71 KiB) Downloaded 1637 times
Return to “Chest Deflection Measurement”
