As a first attempt I created an overview figure for most test objects used in impact and sled tests.
See also
http://www.iso-mme.org/forum/viewtopic.php?f=38&t=423
Integrated are the figures for all variants of deformable elements as defined at the forum topic:
http://www.iso-mme.org/forum/viewtopic.php?f=38&t=426
For load cell matrices I have attached examples for the current usage of the naming conventions
together with two variants of alternative naming as a base of discussion.
Peter Derpmann-Hagenström
Proposal 20150122 - MME 1.6 Revision 2 and MME 2.0
- ISO_LOMA_16R2_20150122.pdf
- Load cell matrices
- (845.71 KiB) Downloaded 1300 times
- ISO_DEFO_16R2_20150122.pdf
- Test objects and its parts
- (1.81 MiB) Downloaded 1326 times
Proposal 20150323 - MME 1.6 Revision 2 and MME 2.0
As a result of the discussion at the last MME TaskForce Meeting in Wolfsburg
the following figures were created:
- ISO_DEFO_16R2_20150324.pdf
- defo elements and other objects - pdf version from 2015-03-24
- (2.11 MiB) Downloaded 1326 times
- ISO_LOMA_16R2_20150313.pdf
- load cell matrices - pdf version from 2015-03-13
- (779.74 KiB) Downloaded 1205 times
