SIDIIs FineLoc1 and 2 for thorax locations
Posted: Thu Dec 11, 2008 11:06 am
I have doubts about SID IIs dummy ISO label for Abdominal and Toracic Rib: Fine location 1 and Fine Location 2 have different rules than the rest of side impact dummies.
Reading carefully the last published ISO TC 22 / SC 12 WG3 (ISO/TS 13499 - 2007) I could noticed confusion regarding the Calculated Value Codes 'VCCR', 'VCAR' and the related channels 'TRRI' and 'ABRI'.
FineLoc1 must be LE or RI for VCCR and VCAR (for side impact dummies) and 01, 02, 03 for FineLoc2. This is a strict rule in the Calculated Values Codes and Channels version 1.5.
The confusion comes from the rest of the documents 'Channel Codes' and 'figures' in which the FineLoc1 and FineLoc2 are exchanged for SID IIs dummy (abdominal and Toracic Ribs).
The rest of side impact dummies (like ES2) use FineLoc1 for LE and RI locations and UP,MI, LO in Fineloc2.
Example:
??TRRI01LES2DSYC ----->??VCCR01LES2VEYX BUT it is mandatory ??VCCRLE01S2VEYX according RED E DOCUMENT (2007 v1.5)
Example:
