HS = HighSampling
Make suggestions here for changes to existing codes.
HS = HighSampling
In Some applications a sensor is capable to deliver data in different sample rates. So the whole ISO Code would be the same. To provide a marker for a channel with high sample rate (e.g. 100kHz) there is a designator needed.
The proposal is a HS in FL2 .
FL3 is needed for dummy channels and FL1 is often in use.
If there is a high rate sampling variant of a channel which uses all positions in the ISO code there might be a chance to prepare a combined code on FL1 like we have done for some CVC's:
******LELO****** -> ******LLHS******
Re: HS = HighSampling
Accepted and in Database. 1.6p1
1 July 2011, Netmeeting.
Return to “Corrections to existing codes”
