ISO Codes for RibEye™ Multi-point Deflection Measurement
Posted: Tue Aug 18, 2009 8:22 am
by wuelfing
Hello to the members of the forum!
Has anybody already used the RibEye™ multi-point deflection measurement system from Boxboro Systems
(http://www.boxborosystems.com/products.html)
I would suggest to use the existing main locations and 'DS' for the dimension (e.g. 11RIBSRI01H3DSXP, ...).
For the S2 dummy some codes for the distance measurement already exist (e.g. 11TRRI01LES2DSYP, ...).
I would suggest to use the redundant indicators of the fine location 2 like L1, L3, L4, etc..
Or should we add new fine loactions to indicate the 'RibEye™' system?
Maybe it is also advisable to add the solution for the ISO codes to the possible channel list, so everybody knows which codes should be used with the RibEye™ system?
Re: ISO Codes for RibEye™ Multi-point Deflection Measurement
Posted: Fri Jul 01, 2011 8:58 am
Item opened at netmeeting 1 July 2011 for further discussion.
Posted: Fri Jul 01, 2011 8:59 am
new situation
Posted: Fri Jul 01, 2011 9:07 am
Outcome of discussion:
We will contact Boxboro to request that their codes comply to the ISO-MME codes!
PDH will do this.
Item remains open for now for further discussion as required.
Posted: Wed Sep 11, 2013 9:16 am
