Hi Dirk,
I'm using RED E (version 1.5 from the forum), and you have the Combined Acetabulum and Iliac Peak Force requiring subset T2. However, T2 needs a single time for the event and I'm not convinced that you can specify a time for this calculation: the two forces will peak at different times and all that the calculation does is to add them up, irrespective of when they occur. I think it should be T1 instead (analysis start and end times only).
Combined Acetabulum and Iliac Peak Force in RED E
Re: Combined Acetabulum and Iliac Peak Force in RED E
Hi Paul,
you first have to add the two channels and then determine the maximum of the sum channel.
Please find the explanation of IIHS for total pelvic force attached.
Bye
Bye
