Proposal 8 - Open issue - Codeextension in Channel Filenames
Posted: Fri Dec 04, 2009 1:42 pm
Is it allowed to use <testnumber>_<channelcode>.mmd for channel file names if only local transducer channels are exchanged?
In proposal 8 the following specification is used in RED A 1.3.4:
Allowed filenames are built by the <testnumber>, the <channelcode> defined in the related electronic document Channel Codes and the <codeextension>. The recommended <codeextension> (see 2.16) for transducer channel files with a local reference system according to SAEJ211 is “LOC_T”. If no other <codeextension> is used “_LOC_T” can be omitted.
Problems:
  • 1) Channel filenames can occur in two different types.
  • 2) Channel filenames have to be changed, if channels with other Codeextension (Reference Coordinate System or Origin) are added
  • 3) If the Codeextension don't have to be ommitted, for most of the exchanges dispensable information has to be created.
Solutions:
  • A) We ignore the problems 1 and 2 and accept the proposal 8
  • B) We ignore the problem 3 and ommit the last sentence of the proposal 8 specification
  • C) I describe another solution
My preference:
I prefer solution B
Re: Proposal 8 - Open issue - Codeextension in Channel Filenames
Posted: Fri Apr 23, 2010 9:21 am
Open issue – code extension in channel filenames
_LOC_T : local co-ordinates, transducer channel. This includes channels calculated from transducer. We revisited the option of omitting this for transducer-only data transfer. We decided to adopt solution A [We ignore the problems 1 and 2 and accept the proposal 8] with a change to RED-A. We decided that LOC_T will always be omitted and therefore will be deleted from the examples in table 2.16.
