Proposal 8 - Open issue - Reference system id
Posted: Fri Dec 04, 2009 2:23 pm
				 Should the descriptor Reference system id in channel files be mandatory or optional
In proposal 8 the descriptor .Reference system id is optional (see RED A 1.3.4.1)
Problems:
Solutions:
I prefer solution C.
D: A second solution would be B in conjunction with open issue
http://www.iso-mme.org/forum/viewtopic.php?f=35&t=150 solution C (-> optional, but without a dot)
Problems:
- 1) If the descriptor is mandatory it is redundant information. It is equivalent to a part of the Codeextension if the extension may not be ommitted (see open issue http://www.iso-mme.org/forum/viewtopic.php?f=35&t=152)
- 2) If the descriptor is optional it has to start with a "."
(see open issue http://www.iso-mme.org/forum/viewtopic.php?f=35&t=150 )
- 3) If the descriptor is unnecessary the Codeextension don't have to be omitted.
Solutions:
- A) The descriptor is mandatory.
- B) The descriptor is optional.
- C) The descriptor is unnecessary.
- D) I describe another solution.
