KT supplied me a list of codes that seems to be doubled or mistaken in the ISO MME DB delivered with version 1.5.
I verified that these issues are also relevant in the current release and prepared an answer for the request in the following.
Some recommendations for future indications of problems with the database in advance:
- Supply information here in the forum to allow all people to participate in the issues.
- I would like to ask for all problem indications to please supply the ID of the entry in the table to simplify the analysis.
- Please verify when comparing for double codes, that you are not using expired and active codes at the same time.
- Please verify double codes in the database table and not after extracting just a part of the code!
Double ISO Codes in Possible Channels
Der ISO Code '??FARMRI00S2MOY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 82: ??FARMRI00S2MOY? (Forearm Right Moment Y)
S2 Dummy/ 83: ??FARMRI00S2MOY? (Forearm Right Moment Y)
Code is misspelled MOZ missing; German longname was correct;
FARM is expired -> use FOAR!
Will be fixed in DB 1.6 P3
Der ISO Code '??HUMSLE00S2MOY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 58: ??HUMSLE00S2MOY? (Humerus Left Moment Y)
S2 Dummy/ 59: ??HUMSLE00S2MOY? (Humerus Left Moment Y)
HUMS is expired -> use UPAR!
Der ISO Code '??ABSP02LES2ACZ?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 190: ??ABSP02LES2ACZ? (Abdominal Spine 5 Left Acceleration Z)
S2 Dummy/ 380: ??ABSP02LES2ACZ? (Abdominal Spine 2 Left Acceleration Z)
Code with Spine 5 is expired (Version 1) updated Code is Version 8
Der ISO Code '??ABSP01LES2ACZ?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 184: ??ABSP01LES2ACZ? (Abdominal Spine 4 Left Acceleration Z)
S2 Dummy/ 374: ??ABSP01LES2ACZ? (Abdominal Spine 1 Left Acceleration Z)
Code with Spine 4 is expired (Version 1) updated Code is Version 8
Der ISO Code '??ABSP02RIS2ACY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 192: ??ABSP02RIS2ACY? (Abdominal Spine 5 Right Acceleration Y)
S2 Dummy/ 382: ??ABSP02RIS2ACY? (Abdominal Spine 2 Right Acceleration Y)
Der ISO Code '??ABSP01RIS2ACZ?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 187: ??ABSP01RIS2ACZ? (Abdominal Spine 4 Right Acceleration Z)
S2 Dummy/ 377: ??ABSP01RIS2ACZ? (Abdominal Spine 1 Right Acceleration Z)
Der ISO Code '??ABSP01RIS2ACY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 186: ??ABSP01RIS2ACY? (Abdominal Spine 4 Right Acceleration Y)
S2 Dummy/ 376: ??ABSP01RIS2ACY? (Abdominal Spine 1 Right Acceleration Y)
Der ISO Code '??ABSP02LES2ACY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 189: ??ABSP02LES2ACY? (Abdominal Spine 5 Left Acceleration Y)
S2 Dummy/ 379: ??ABSP02LES2ACY? (Abdominal Spine 2 Left Acceleration Y)
Der ISO Code '??ABSP01LES2ACY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 183: ??ABSP01LES2ACY? (Abdominal Spine 4 Left Acceleration Y)
S2 Dummy/ 373: ??ABSP01LES2ACY? (Abdominal Spine 1 Left Acceleration Y)
Der ISO Code '??ABSP02RIS2ACX?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 191: ??ABSP02RIS2ACX? (Abdominal Spine 5 Right Acceleration X)
S2 Dummy/ 381: ??ABSP02RIS2ACX? (Abdominal Spine 2 Right Acceleration X)
Der ISO Code '??ABSP02RIS2ACZ?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 193: ??ABSP02RIS2ACZ? (Abdominal Spine 5 Right Acceleration Z)
S2 Dummy/ 383: ??ABSP02RIS2ACZ? (Abdominal Spine 2 Right Acceleration Z)
Der ISO Code '??ABSP01RIS2ACX?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 185: ??ABSP01RIS2ACX? (Abdominal Spine 4 Right Acceleration X)
S2 Dummy/ 375: ??ABSP01RIS2ACX? (Abdominal Spine 1 Right Acceleration X)
Der ISO Code '??ABSP01LES2ACX?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 182: ??ABSP01LES2ACX? (Abdominal Spine 4 Left Acceleration X)
S2 Dummy/ 372: ??ABSP01LES2ACX? (Abdominal Spine 1 Left Acceleration X)
Der ISO Code '??ABSP02LES2ACX?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 188: ??ABSP02LES2ACX? (Abdominal Spine 5 Left Acceleration X)
S2 Dummy/ 378: ??ABSP02LES2ACX? (Abdominal Spine 2 Left Acceleration X)
Der ISO Code '??SPIN0100S2ACY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 91: ??SPIN0100S2ACY? (Spine Upper (T1) Acceleration Y)
S2 Dummy/ 93: ??SPIN0100S2ACY? (Spine Upper (T1) Acceleration Y)
Full Code in DB was ??SPIN0100S2ACYC and ??SPIN0100S2ACY1
As CFC selection will not been output one entry will be removed!
Der ISO Code '??PELV0000S2ACY?' ist für die folgenden Messstellen definiert:
S2 Dummy/ 209: ??PELV0000S2ACY? (Pelvis Acceleration Y)
S2 Dummy/ 211: ??PELV0000S2ACY? (Pelvis Acceleration Y)
Full Code in DB was ??PELV0000S2ACYC and ??PELV0000S2ACY1
Der ISO Code '??SPIN0100SHACY?' ist für die folgenden Messstellen definiert:
SH Dummy/ 18: ??SPIN0100SHACY? (Spine Upper (T1) Acceleration Y)
SH Dummy/ 20: ??SPIN0100SHACY? (Spine Upper (T1) Acceleration Y)
Full Code in DB was ??SPIN0100SHACYC and ??SPIN0100SHACY1
Because there is another entry missing for SH that exists for SI, I will change the Entry to
??SPIN01RDSHACY? Spine Upper (T1) Redundant
Der ISO Code '??PELV0000SHACY?' ist für die folgenden Messstellen definiert:
SH Dummy/ 26: ??PELV0000SHACY? (Pelvis Acceleration Y)
SH Dummy/ 28: ??PELV0000SHACY? (Pelvis Acceleration Y)
Full Code in DB was ??PELVRD00SHACYC and ??PELVRD00SHACY1
??PELVRD00SHACY? Pelvis Redundant Acceleration Y
Der ISO Code '??SPIN1200SHACY?' ist für die folgenden Messstellen definiert:
SH Dummy/ 22: ??SPIN1200SHACY? (Spine Lower (T12) Acceleration Y)
SH Dummy/ 24: ??SPIN1200SHACY? (Spine Lower (T12) Acceleration Y)
Full Code in DB was ??SPIN1200SHACYC and ??SPIN1200SHACY1
??SPIN12RDSHACY? Spine Upper (T12) Redundant
Der ISO Code '??PELV0000SIACY?' ist für die folgenden Messstellen definiert:
SI Dummy/ 30: ??PELV0000SIACY? (Pelvis Acceleration Y)
SI Dummy/ 33: ??PELV0000SIACY? (Pelvis Acceleration Y)
Full Code in DB was ??PELV0000SIACYC and ??PELV0000SIACY1
Der ISO Code '??SPIN0100SIACY?' ist für die folgenden Messstellen definiert:
SI Dummy/ 7: ??SPIN0100SIACY? (Spine Upper (T1) Acceleration Y)
SI Dummy/ 10: ??SPIN0100SIACY? (Spine Upper (T1) Acceleration Y)
Full Code in DB was ??SPIN0100SIACYC and ??SPIN0100SIACY1
Der ISO Code '??SPIN01RDSIACY?' ist für die folgenden Messstellen definiert:
SI Dummy/ 8: ??SPIN01RDSIACY? (Spine Upper (T1) Redundant Acceleration Y )
SI Dummy/ 11: ??SPIN01RDSIACY? (Spine Upper (T1) Acceleration Y Redundant)
Full Code in DB was ??SPIN01RDSIACYC and ??SPIN01RDSIACY1
Der ISO Code '??SPIN1200SIACY?' ist für die folgenden Messstellen definiert:
SI Dummy/ 13: ??SPIN1200SIACY? (Spine Lower (T12) Acceleration Y)
SI Dummy/ 15: ??SPIN1200SIACY? (Spine Lower (T12) Acceleration Y)
Der ISO Code '??PELVRD00SIACY?' ist für die folgenden Messstellen definiert:
SI Dummy/ 31: ??PELVRD00SIACY? (Pelvis Redundant Acceleration Y )
SI Dummy/ 34: ??PELVRD00SIACY? (Pelvis Redundant Acceleration Y)
Full Code in DB was ??PELVRD00SIACYC and ??PELVRD00SIACY1
??PELVRD00SHACY Pelvis Redundant Acceleration Y
Der ISO Code '??RDCRLEMI??DSYX' ist für die folgenden Messstellen definiert:
Calculation/ 51: ??RDCRLEMI??DSYX (Rib Deflection Criterion Left Chest Middle)
Calculation/ 130: ??RDCRLEMI??DSYX (Rib Deflection Criterion Left Chest Middle)
Code is doubled one entry will be removed
Der ISO Code '??TIRALUFZHM00Z?' ist für die folgenden Messstellen definiert:
HM Dummy/ 82: ??TIRALUFZHM00Z? (Tibia Ratio Left Upper Force)
HM Dummy/ 125: ??TIRALUFZHM00Z? (Tibia Ratio Right Upper Force)
Second Entry should be ??TIRARUFZHM00Z? (Tibia Ratio Right Upper Force)
according to correct ly given Long Name
Der ISO Code '??TIRALLFZHM00Z?' ist für die folgenden Messstellen definiert:
HM Dummy/ 83: ??TIRALLFZHM00Z? (Tibia Ratio Left Lower Force)
HM Dummy/ 126: ??TIRALLFZHM00Z? (Tibia Ratio Right Lower Force)
Second Entry should be ??TIRARLFZHM00Z? (Tibia Ratio Right Lower Force)
according to correctly given Long Name
Thanks to Mr. Oliver Schnaus from KT for the checking.
Correction to Codes in DB 1.5 -> 1.6p3
Re: Correction to Codes in DB 1.5 -> 1.6p3
All issues have been solved in the 1.6p3 version of the database backend:
http://www.iso-mme.org/forum/viewtopic.php?f=60&t=211
