I'm looking for a definition for channel codes of tracking datas.
In the appendix you find my proposals for all tracking channels we used at faurecia.
I know some tracking points very specially but some are standard.
As important I regard tracking datas of lowspeed tests, for example BioRID.
Are already codes defined?
Bets regards
Uwe Carstensen
ucarstensen
- Company: Faurecia automotive seating GmbH
- faurecia_H3_FMVSS202a_designation_tracking_channels.pdf
- FMVSS202a
- (41.34 KiB) Downloaded 1239 times
- faurecia_designation_tracking_channels.pdf
- general
- (142.49 KiB) Downloaded 1300 times
- faurecia_BioRID_designation_tracking_channels.pdf
- BioRID
- (42.31 KiB) Downloaded 1087 times
Uwe Carstensen
FAS R&D - Global Validation Services
Faurecia Automotive Seating
Garbsener Landstraße 7
30419 Hannover
Germany
uwe.carstensen@forvia.com
30419 Hannover
Germany
Re: channel codes of tracking datas
up to now for filmanalysis tracking data no special coding is standardized.
But there are some general rules which can be applied to this kind of codes.
Currently a group of german car manufacturers is working on filmanalysis of whiplash tests.
I will try to get a harmonized list of codes from this group.
For now I will give your my opinion to your proposal
- channels attached to the seat are not related to the dummy type
- the FineLocations RI/LE should replace IN/OU
- LE/RI should be the FineLocation1
- the CenterofGravity CG is not at the side of the head -> should be MI
- Filmanalysis_ChannelCodes_for_Whiplash_20100830.pdf
- proposal VW for whiplash filmanalysis channel codes
- (29.64 KiB) Downloaded 1361 times
ucarstensen
Thank you very much for this information.
Uwe Carstensen
Uwe Carstensen
Uwe Carstensen
30419 Hannover
Germany
30419 Hannover
Germany
Included on Whiplash figure.
Item closed at on-line meeting 20120216.
