Battery Voltage Codes
Posted: Wed Sep 08, 2010 7:30 am
I have got a request for additional codes of power supply measurements in the vehicle. It seems to be typical to measure at the "Klemme 15" (Pin 15?) to monitor the "Main Power Supply" and also the Power Supply to the Central Unit. These measurements will be made as additional measurements to the direct measurement on the battery.
The Proposal is to add new possible channels based on existing code parts:
?0BATT15????VO0?; Power Supply at Pin 15; Versorgungsspannung Klemme 15
?0CEUN??????VO0?; Power Supply Central Unit ; Versorgungsspannung Airbagsteuergerät
Any other ideas or concerns?
