Coding for Hybrid III String Pot Chest
Posted: Wed Feb 22, 2012 7:47 pm
Greetings,
I'm writing to request additional codes, but I'm not sure what would be best. Here's the scenario...
There are variants of the 50th male and 5th female Hybrid III dummy with a "string pot chest", which measures the displacement of four locations on the anterior rib cage relative to the spine. To measure these four quadrants (upper left, upper right, lower left, lower right), there are eight string pots mounted to the spine. For each location, two string pots are attached to the rib at the anterior location and attached to opposite sides of the spine at the posterior location. So, each location has a "straight" (e.g. left rib to left of spine) and "cross" (e.g. left rib to right of spine) string pot.
In case it helps, I'm attaching a diagram that shows a cross-section of the dummy's chest looking down.
For the "straight" channels, these correspond to the X-axis of the dummy, so the codes might be: ??CHSTLEUPH3DSXP, ??CHSTLELOH3DSXP, ??CHSTRIUPH3DSXP, ??CHSTRILOH3DSXP
However, for the "cross" channels, these do not correspond to the Y-axis of the dummy, so setting the axis character to "Y" would be misleading. In this case, would it be best to add a new axis designation ("C" for "cross"), or to use "LL/LU/RL/RU" as FL1 and add maybe "CR" for FL2?
Thanks for your assistance!
- Dan
- Dan
