Dummy Certification
Discussion about the values for Type of test, Subtype of test and Regulation
Dummy Certification
The current proposal for the Testtypes, Subtypes and Regulations of Dummy Certification Tests is stored here.
In addition all measured channels are listed for every Subtype.
DummyCertification_20170216.xlsx
Updated proposal from 16.02.2017: all filterclasses P
(5.18 MiB) Downloaded 1577 times
DummyCertification_20170105.xlsx
Updated proposal from 05.01.2017
(5.18 MiB) Downloaded 1444 times
DummyCertification_20160628.xlsx
Updated version after discussion in webmeeting 28.06.2016
(5.16 MiB) Downloaded 1428 times
DummyCertification_20160622.xlsx
Updated proposal from 22.06.2016
(5.16 MiB) Downloaded 1480 times
DummyCertification_20160303.xlsx
Updated proposal DPH
(4.99 MiB) Downloaded 1421 times
DummyCertification_20151026.xlsx
Updated proposal with channel codes and figures
(4.99 MiB) Downloaded 1537 times
DummyCertification_20151013.xlsx
Updated proposal including all Q-dummies
(74.43 KiB) Downloaded 1537 times
DummyCertification_20150911.xlsx
Updated proposal including pedestrian impactors, some Q-dummies, THOR
(34.32 KiB) Downloaded 1615 times
MME-Forum_DummyCertification_20121025.xls
List of types and subtypes of test and the related regulations for dummy certification tests
(71.5 KiB) Downloaded 1697 times
Re: Dummy Certification
Dear Peter,
for the THOR there is a "new" Qualification Manual 08_2016 available.
The procedures and channels are the same. Only some parameters and
the corridors have changed.
We have renamed the procedure "Knee Impact Left/Right" to "Upper Leg Impact Left/Right".
So the naming corresponds to the naming in the NHTSA document.
2016_08_THOR-50M_Qualification.pdf
NHTSA Qualification Manual August 2016
(7.2 MiB) Downloaded 1589 times
The document with the THOR updates 'Qualification Manual Version'
and change of the subtypes 'Knee Impact...' to 'Upper Leg Impact...'
you will find here:
DummyCertification_20180820.xlsx
Update with THOR changes
(5.18 MiB) Downloaded 1523 times
Return to “Testtypes, Subtypes and Regulations”
