in the MME version 1.6 only the exchange of linear and 3rd order polynomial regression calibrated channels has been described.
A new situation arises with the nonlinear transducers of the IR-TRACC.
To handle IR-TRACC displacement and angle transducers similar to all other transducers
we want to propose a system of descriptors for channel data files covering the needs of all known use cases .
This solution also gives flexibility for future developments.
A central element of this solution is the new descriptor .Transfer function used
Dependent on this descriptor a set of parameters (new or existing descriptors) used for the calibration has to be exchanged.
For details please see the attached presentation.
Kind Regards
Peter Derpmann-Hagenstroem
Transducer - Transfer Functions
- ISO_TS13499_RED_A_V16Rev2_20160307.pdf
- Implementation of the transfer functions in MME 1.6 RED A Revision 2
- (154.08 KiB) Downloaded 1058 times
- 20150527_Transferfunctions.pdf
- updated proposal from 27.05.2015 including .sensitivity for linear regression
- (369.32 KiB) Downloaded 986 times
- 20141217_Transferfunctions.pdf
- updated proposal from 17.12.2014
- (384.19 KiB) Downloaded 910 times
- 20140903_Transferfunctions.pdf
- Presentation of new descriptors for linear and nonlinear transfer functions
- (360.26 KiB) Downloaded 973 times
