Proposal 20150122 - MME 1.6 Revision 2 and MME 2.0
Test Objects and Parts of Test Objects like Load Cell Matrices, Deformable Elements
As a first attempt I created an overview figure for most test objects used in impact and sled tests.
See also
http://www.iso-mme.org/forum/viewtopic.php?f=38&t=423
Integrated are the figures for all variants of deformable elements as defined at the forum topic:
http://www.iso-mme.org/forum/viewtopic.php?f=38&t=426
For load cell matrices I have attached examples for the current usage of the naming conventions
together with two variants of alternative naming as a base of discussion.
Peter Derpmann-Hagenström
ISO_LOMA_16R2_20150122.pdf
Load cell matrices
(845.71 KiB) Downloaded 1296 times
ISO_DEFO_16R2_20150122.pdf
Test objects and its parts
(1.81 MiB) Downloaded 1319 times
Proposal 20150323 - MME 1.6 Revision 2 and MME 2.0
As a result of the discussion at the last MME TaskForce Meeting in Wolfsburg
the following figures were created:
ISO_DEFO_16R2_20150324.pdf
defo elements and other objects - pdf version from 2015-03-24
(2.11 MiB) Downloaded 1318 times
ISO_LOMA_16R2_20150313.pdf
load cell matrices - pdf version from 2015-03-13
(779.74 KiB) Downloaded 1197 times
Return to “Other Figures”
