At the web-meeting/telephone conference from 11.02.2015 the users and software developers
wished to get testdata for 2D IR-TRACCs.
Humanetics agreed on delivering some data coming from dummy certification tests.
In addition VW created testdata by manually moving an IR-TRACC between three positions of the fixture.
The time scale is approximately 10 seconds. The movement is filmed.
The movie is nearly synchronized and stored in the movie subdirectory.
The angle and length is measured with a DTI system and stored in two channels (DC and AN)
using the code for an abdominal rib of a WS dummy.
The transfer parameters in the channel headers are changed according to the transfer function proposal from 17.12.2014:
http://www.iso-mme.org/forum/viewtopic. ... p=722#p722
The MME version of the testdata is 1.6 with some extensions for the transfer function data (see above)
Testdata
Testdata
- IR-TRACC_Test_v1.zip
- Testdata set of a manually moved 2D IR-TRACC incl. documentation movie
- (4 MiB) Downloaded 1387 times
Re: Testdata
Bernard Been from Humanetics has prepared a second testdata set of a 2D-IRTRACC within a calibration fixture.
I had to split the xlsx file with 4 measurement sheets into 4 xlsx files each containing the same calibration data
because of size restrictions.
- Calibration Documents.zip
- calibration sheets
- (759.94 KiB) Downloaded 1238 times
- Sample data sets 2DIRTRACC Part43208.zip
- 4. testdata sheet
- (3.29 MiB) Downloaded 1354 times
- Sample data sets 2DIRTRACC Part42842.zip
- 3. testdata sheet
- (3.32 MiB) Downloaded 1304 times
- Sample data sets 2DIRTRACC Part42533.zip
- 2. testdata sheet
- (3.3 MiB) Downloaded 1292 times
- Sample data sets 2DIRTRACC Part41714.zip
- 1. testdata sheet
- (3.7 MiB) Downloaded 1306 times
