New figures for Active Safety Tests and deformable barriers
the current figure for deformable elements is updated with the new oblique barrier from the NHTSA test procedure
as decided at the MME TF meeting 28.01.15 in Wolfsburg.
The code for this defo element is DB.
The ADAC test procedure for the car to car (barrier to car) test is available.
The deformable element used in this procedure (Mobile Progressive Deformable Barrier) should be named DM
as decided at the MME TF netmeeting 15.04.15.
This barrier is also integrated on page 1 of the 'Object-Figures'-Document.
Page 2 is not touched and shows the various testobjects for impacts, rollover and sled tests.
The new page 3 is a proposal for the assignment of testobjects in active safty tests like
  • AEB - Autonomous Emergency Breaking
  • VRU - Vulnerable Road Users
  • FCW - Forward Collision Warning
  • LDW - Lane Departure Warning
  • LKA - Lane Keeping Assist
  • LSS - Lane Support Systems
This figures should be discussed at the net MME TaskForce netmeeting.
ISO_OBJ_16R2_20160229.pdf
pdf document showing test objects constellations
(3.12 MiB) Downloaded 1274 times
Re: New figures for Active Safety Tests and deformable barri
Results of the discussion MME-TF 09.03.16:
  • The new FineLocation3 DM for the DEFO-element of the Mobile Progressive Deformable Barrier MPDB
    is accepted and will be inserted into the MME-DB.
  • The updated figures should be referenced in RED A as a hint for the usage of testobjects
    and not directly integrated into the MME-DB.
Dear colleeagues,
DM and all other FL3 codes for barriers have been added to database 1.6 Rev2 Proposal1:
http://www.iso-mme.org/forum/viewtopic.php?f=105&t=495
the formerly combined figures are separated.
For details please see:
viewtopic.php?f=143&t=504
For the active safety Codes please see:
viewtopic.php?f=145&t=476
This item is closed
