New Fine Location 3 for "Interactive Airbag"
ThomasK
Company: Audi AG
Post by ThomasK »
I would like to propose a new fine flocation three for the Interactive Airbag and the related generator.
The currently available airbag types (generators) are
AF - frontal airbag (GF)
AH - head airbag (GH)
AP - pedestrian airbag (GP)
AR - rear airbag (GR)
AS - side airbag (GS)
As new airbag type I propose:
AI - Interactive Airbag / GI - Interactive Airbag Generator
The exact location of the airbag can be defined like before by using existing seat positions.
Regards,
Thomas
Re: New Fine Location 3 for "Interactive Airbag"
Dear Thomas,
Your proposal looks sensible. We have planned the next meeting on the 30th of June (next week) and can discuss your proposal there.
I checked the database for similar codes for FL3 and your proposal should work fine. The only code that might "look" similar is the
expired "G1" for "Belt Loop (Reel Return)", German = "Gurtrolle"
I personally haven't seen this coding so far.
As you mentioned that the rest of the coding could be done by the existing seating positions:
To which SP should the interaction airbag assigned to in the second row?
-> May always to the outer position (4 and 6)?
I hope I interpreted "Interactive airbag" right as a type of airbag that should prevent
occupant interaction?
ThomasK
Company: Audi AG
Post by ThomasK »
Dear Dirk,
your interpretation is absolutely correct; it should prevent occupant interaction.
Regarding your question of the SP in the second row.
In my opinion it depends on the configuration the airbag is used in. My intention - at the moment - is to use SP5 as it is only used in 4-seater - nevertheless I am open for other inputs.
Regards,
Thomas
ThomasK
Company: Audi AG
Post by ThomasK »
Some example channels:
12AIRB0000GIEV00 - Interaction Airbag front
15AIRB0000GIEV00 - Interaction Airbag rear
12AIRB0000GIVO0P - ignition voltage Interaction Airbag front
15AIRB0000GIVO0P - ignition voltage Interaction Airbag rear
12AIRB0000GICU0P - ignition current Interaction Airbag front
15AIRB0000GICU0P - ignition current Interaction Airbag rear
12AIRB0001GIEV00 - Timer Interaction Airbag front
15AIRB0001GIEV00 - Timer Interaction Airbag rear
12AIRB0001GIVO0P - Timer Interaction Airbag front
15AIRB0001GIVO0P - Timer Interaction Airbag rear
12AIRB0001GICU0P - Timer Interaction Airbag front
15AIRB0001GICU0P - Timer Interaction Airbag rear
12AIRB0000AIPR0P - internal pressure Interaction Airbag front
15AIRB0000AIPR0P - internal pressure Interaction Airbag rear
Codes have been added to the figure.
Please see:
viewtopic.php?f=79&t=506
I have now added the following codes to the database:
Table FL3:
AI	Interaction Airbag		       Interaktion Airbag
GI	Interaction Airbag Generator	Interaktion Airbag Generator
Table Possible channels:
?2AIRB????AIPR0?;  Pressure Interaction Airbag front;         Interaktion Airbag Druck vorn
?5AIRB????AIPR0?;  Pressure Interaction Airbag rear;          Interaktion Airbag Druck hinten
?2AIRB????AI??0?;  Interaction Airbag front;                  Interaktion Airbag vorn
?5AIRB????AI??0?;  Interaction Airbag rear;                   Interaktion Airbag hinten
?2AIRB????GIEV0?;  Interaction Airbag Ignition front;         Interaktion Airbag Zündung vorn
?5AIRB????GIEV0?;  Interaction Airbag Ignition rear;          Interaktion Airbag Zündung hinten
?2AIRB????GIVO0?;  Interaction Airbag Ignition voltage front; Interaktion Airbag Zündungspannung vorn
?5AIRB????GIVO0?;  Interaction Airbag Ignition voltage rear;  Interaktion Airbag Zündungspannung hinten
?2AIRB????GICU0?;  Interaction Airbag Ignition current front; Interaktion Airbag Zündungstrom vorn
?5AIRB????GICU0?;  Interaction Airbag Ignition current rear;  Interaktion Airbag Zündungstrom hinten
?2AIRB????GI??0?;  Interaction Airbag Generator front;        Interaktion Airbag Generator vorn
?5AIRB????GI??0?;  Interaction Airbag Generator rear;         Interaktion Airbag Generator hinten
Please review the codes as I have implemented slightly different ones from the AUDI example.
In the FL3 longnames I have added "Airbag" in the Generator Longname as
this is also to be found for other Airbag codes in FL3 table.
