Correction needed Y7 -> SPIN01 ACX -> SPINUP ACX
Dear coleagues,
Christian Brockhusen unveiled that there is a mismatch in the Y7 (H3 6Year) dummy figure and the database.
In the original figure Y7_1_11.wmf we have coded the measurement on the upper Spine as
??SPINUP00Y7ACX?.
This corresponds to the naming of the second height level: ??SPINLO00Y7ACX?.
Also there are two additional measurements on the Sternum with the UP and LO
coding approoach: ??STRNUP00Y7ACX?, ??STRNLO00Y7ACX?.
These measurements will also be used to generate relative deflection from acceleration.
Now, with the reneval of the Y7 figure to the 3 page standard format we might have had
a little copy and paste issue and now the coding is: ??SPIN0100Y7ACX?
I reviewed also the 2015 approach from Peter: "20150415_Dummy_Status_DBvsFigures.xls":
Also here we have used the SPINUP-variant.
This is also the current code in the database.
After this long text my finally proposal is to switch back to the SPINUP variant in the Y7 figure page 2.
Return to “Child Dummy Y-series (Y2, Y6, Y7, YA)”
