RED A - History
RED A - History
Proposal 2 of RED A for MME 2.0 from 08.10.2007.
Proposal 3 of RED A for MME 2.0 from 06.03.2008.
Proposal 4 of RED A for MME 2.0 from 04.09.2008.
Proposal 5 of RED A for MME 2.0 from 31.03.2009.
Proposal 6 of RED A for MME 2.0 from 22.04.2009.
Proposal 7 of RED A for MME 2.0 from 29.10.2009.
Proposal 8 of RED A for MME 2.0 from 03.12.2009.
Draft version of RED A for MME 2.0 from 03.05.2010.
Draft version of RED A for MME 2.0 from 19.10.2010.
Draft version of RED A for MME 2.0 from 23.09.2011.
Draft version of RED A for MME 2.0 from 12.12.2011.
:!: Final version of RED A for MME 2.0 for the voting process in ISO/TC22/SC12.
Final version with color marked changes to MME 1.6.
ISO_TS13499_RED_A_V2_Draft_20120131.pdf
Version with the marked changes
(788.33 KiB) Downloaded 1336 times
ISO_TS13499_RED_A_V2.pdf
Final version for the voting process
(770.61 KiB) Downloaded 1354 times
ISO_TS13499_RED_A_V2_Draft_20111212.pdf
draft version updated discussed at the TF netmeeting 13.12.2011
(778.63 KiB) Downloaded 1366 times
ISO_TS13499_RED_A_V2_Draft_20110921.pdf
draft version updated after the TF netmeeting 23.09.2011
(756.94 KiB) Downloaded 1277 times
ISO_TS13499_RED_A_V2_Draft_20101019.pdf
draft version updated after the TF netmeeting 08.09.2010
(142.66 KiB) Downloaded 1397 times
ISO_TS13499_RED_A_V2_Draft_20100503.pdf
draft version
(137.02 KiB) Downloaded 1454 times
ISO_TS13499_RED_A_V2_proposal8_20091203.pdf
proposal 8
(666.03 KiB) Downloaded 1443 times
ISO_TS13499_RED_A_V2_proposal7_20091029.pdf
proposal 7
(644.11 KiB) Downloaded 1503 times
ISO_TS13499_RED_A_V2_proposal6_20090422.pdf
proposal 6
(659.88 KiB) Downloaded 1421 times
ISO_TS13499_RED_A_V2_proposal5_20090331.pdf
proposal 5
(656.91 KiB) Downloaded 1525 times
ISO_TS13499_RED_A_V2_proposal4_20080904.pdf
proposal 4
(131.78 KiB) Downloaded 1404 times
ISO_TS13499_RED_A_V2_proposal_20080306.pdf
proposal 3
(155.96 KiB) Downloaded 1476 times
ISO_TS13499_RED_A_V2_proposal_20071008.pdf
proposal 2
(185.08 KiB) Downloaded 1521 times
