Position of Temperature Sensor
Posted: Thu Oct 17, 2019 3:40 pm
by bjoern.hohage
Actually we discuss in the ISO WG3 and WG5 an update of
ISO/TR 27957 Road vehicles — Temperature measurement in anthropomorphic test devices — Definition of the temperature sensor locations
In the actually draft the position of the sensor will move for nearly all dummy from the spine box to the rib left or right - the user can choose between this both positions or can use both at the some time.
Based on this we need an update of the channel code and the drawing for the temperature sensor.
e.g. for the H3:
actual: Spine - TE: THSP 00 00 H3 TE 0
new: Rib - TE: RIBS LE 03 H3 TE 0 and RIBS RI 03 H3 TE 0
When needed I can create the complete list of new sensor names.
Björn
Re: Position of Temperature Sensor
Posted: Mon Oct 21, 2019 9:43 am
Hi Bjoern,
thanks for the information.
I guess we will need to discuss if we include the new location codes beside the existing ones
in the figures and the database or if we do remove the existing ones (THSP0000WSTE00, ...).
At least we should prepare a reference for the new locations, that these are related to the ISO 27957.
A table of the locations would be helpful to prepare our changes.
This change will require nearly all Dummy Figure series to be modified.
Posted: Wed Jun 09, 2021 12:39 pm
by Klaas
Modification of figures referencing ISO27957.
