New physical dimension for calculated angle
Posted: Wed Apr 08, 2020 11:40 am
by pfeiffge
when discussing the physical dimensions VA (velocity calculated of acceleration) and DV (displacement calculated of velocity) I missed a dimension for the angle (AN) when it's calculated of angular velocity.
I would like to discuss (again) if there will be a need for new dimensions in the database. AR (angle calc. of angular Rate) and AV (angular velocity) are already used. There could be possible CA (calculated angle)
Nevertheless there will be the question if we should expand the dimensions.
Thank your for your discussion and opinions
Gerd Pfeiffer
Re: New physical dimension for calculated angle
Posted: Thu Jun 04, 2020 9:32 am
decision of the TaskForce:
in the moment there is no need for alternative coding.
