Other Objects - Deformable Elements - new IIHS
Posted: Thu Oct 01, 2020 11:41 am
by bjoern.hohage
IIHS will introduce a new kind of Moving Deformable Barrier in 2023 with other specs then the actual one.
Question:
do we need a new code for this barrier?
Possibilities:
- Change Fine Location 1 from "00" to "02", because IIHS calls the new version "version 2.0"
- Change Fine Location 3 from "DI" to "DJ" - the next letter after I
Björn
PS Specs:
old version: https://www.iihs.org/media/1e38eb47-3d2 ... r_spec.pdf
new version: https://www.iihs.org/media/98ee5a48-000 ... y 2020.pdf
Re: Other Objects - Deformable Elements - new IIHS
Posted: Thu Oct 01, 2020 7:42 pm
Dear Björn,
very good hint. I would prefer to stay with the "DI" in FL3, to keep the link to IIHS in the code.
Otherwise we need to invent a new FL3 for each variant and might ran out of D-Codes on FL3. :-)
IIHS is calling the barrier specification V2.0 so a 02 should match very well.
M0 DEFO 02 00 DI
If we use FL1 for the number (as you proposed), we will still be able to code subversion in the future
like V2.1: DEFO 02 01
Posted: Wed Mar 10, 2021 2:14 pm
use the code M0DEFO0200DI for the Version 2 of the IIHS barrier.
The figure should be updated.
Posted: Wed Jun 09, 2021 12:32 pm
by Klaas
Actually closed update of figure required as last step.
