Position for Engine
Posted: Fri Oct 02, 2020 12:33 pm
by bjoern.hohage
actual is the Position for engine always 0.
BEVs can have more then one engine with decentral position.
I think it will be better to switch from "0" to "?" as position.
Furthermore the figure "Vehicle Bottom View 3 - Electric Elements" can have an update for this topic, e.g. with a 3 engine configuration.
Björn
PS example:
https://www.faz.net/aktuell/technik-mot ... 59170.html
PS² maybe other electrical components also needs an update.
Re: Position for Engine
Posted: Wed Nov 25, 2020 1:40 pm
TaskForce:
the position information shoul be used
a different MainLocation for electric motors should be created:
  • EMOT- electrical motor
  • ELMO - electrical motor
  • ELMG - electrical motor / generator
  • EMGE - electrical motor / generator
  • ETMO - electrical traction motor
please reply!
Posted: Wed Mar 10, 2021 2:03 pm
for electrical drive motors the code will be:
EDUN - electric drive unit - elektrische Antriebseinheit
The position information should be free = ?
Posted: Wed Mar 10, 2021 5:00 pm
added to the database 1.6.3p1:
Main location:
2021-03-10 17_56_00-Window.png (2.61 KiB) Viewed 42206 times
Possible channels:
2021-03-10 17_55_23-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versi.png
2021-03-10 17_55_23-Access - mme_code _ Datenbank- D__Daten_03_Projekte_10_ISO_02_DB_##Work_01_Versi.png (4.69 KiB) Viewed 42206 times
Kind regard,
Posted: Wed Jun 09, 2021 12:24 pm
by Klaas
This topic is practically closed. It only remains open until the figure in the vehicle description ist updated.
Add line in the bottom part of the figure. Multiple positions might be a smart idea to allow for multiple positioning.
