Attached a Zip-file with three EQX files and a quick description of what is contained.
Please feel free to post your feedback and possible challenges.
Example Datasets
Moderator: AK-ISO-MME
gieschef
- Company: ZF Automotive Germany GmbH
Example Datasets
- EQX_sampledata.zip
- (88.27 KiB) Downloaded 1312 times
Re: Example Datasets
Can you help please with how to define a 3D IRTRACC with radius calibration using the v1.6 XSD ? The problem is I do not see any definition of the equation for when the units are "mm" only mV or LSB.
Attached is my formula for the IRTRACC Radius Cal ...
Thank you
Thank you
- IRTRACC Radius Cal Formula with coeffs.png (239.96 KiB) Viewed 51517 times
Oliver Schnaus
- Company: Kistler Instrumente GmbH
The Zero-Int [mm] can be divided by the Cal.factor [mm/V lin] to obtain the Zero-Int [V lin]. Multiply with 1000 to get it in [mV lin], which is required in Sensitivity3 of the EQX.
The sensitivity needs to be calculated from "mm/V lin" to "mV lin/mm" for the Sensitivity element of the EQX.
