Euro NCAP Draft for Naming convention
Discussion about codes for Active Safety Tests.
Klaas
Company: measX
Post by Klaas »
Hello Everyone,
as discussed in the meeting, Adriano Palao from Euro NCAP proposed an update of the naming convention for Euro NCAP tests.
He kindly shared his thoughts with us in search for input. I put his presentation with his thoughts here for reviev and lively discussion.
DRAFT TB 021 Naming Convention Proposal - V0.1.pdf
(1.29 MiB) Downloaded 1209 times
Re: Euro NCAP Draft for Naming convention
here are some ideas and remarks to the propoal of Euro NCAP to integarte the attibutes in ISO13499 RED F.
There are some new proposals for MME attributes:
.Nom. Heading test object X
.Pos. Offset test object X
.Striking point TO X
.Overlap VUT to TO X
But also differences in naming which should be harmonized:
.Dimension of test object X
.Dimensions test object X
Please see the slides or teh discussion in TF MME active safety for details:
MME_attributes_ISO13499REDF_vs_EuroNCAP.pdf
(163.52 KiB) Downloaded 1368 times
Kind regards
Dear Mr. Washausen,
I would agree that an abbreviation for "test object" will improve the readability of the descriptors.
Leaving more space for relevant words and characters.
I would propose to use "TOB" as abbreviation instead of TO.
here is an update of
(192.43 KiB) Downloaded 1440 times
to TOB instead of TO.
I have also added more details in definition of ".Nominal Heading TOB X".
Best regards,
Return to “Active Safety Codes”
