Additional code for aPLI Moment Channels
Posted: Tue Oct 17, 2023 9:17 am
there is a request for the handling of the Moment Channel Codes for the aPLI.
Basically the codes are already defined and could be found in the database as well as in the figures:
2023-10-13 15_22_21-C__Users_vetter_Desktop_ISO_ MME_aPLI_TibiaMoment Codes.png - Greenshot Editor.png
2023-10-13 15_22_21-C__Users_vetter_Desktop_ISO_ MME_aPLI_TibiaMoment Codes.png - Greenshot Editor.png (20.05 KiB) Viewed 32462 times
Motivation:
As there exists two different procedures to certify the bone, there is a need to mark the method followed and
to may correct the samples in the channel by multiplying with a factor.
There are different ways to "mark" the method used and the need for conversion:
A: provide a constant channel with the moment measurement channel
B: modify the coding of the moment channels to signal the method used
C: assign a new descriptor in the channel to transport the scaling need/factor
Method "A" (additional constant channel)
- requires additional channel(s)
- information not applied to the channel file itself
- allows to provide individual factors for each channel (if that is needed)
Method "B" (change coding)
- visible from outside
- channel is self descriptive
- no individual factor can be applied (if that is needed)
- coding approach needed (space in FL1,FL2; which is which)
Method "C" (add descriptor to each channel)
- decriptor needed for the factor
Method "B" will require a recoding approach. As some codes are already completely used
(TIBIMIUP/TIBIMILO) the FL1 and FL" codes must be compressed to allow a marker text in the code:
2023-10-17 11_06_29-aPLI-dirk.vetter@iatmbh.com - Outlook.png (7.09 KiB) Viewed 32462 times
It would be helpful to get feedback from the users of this device for the preferred implementation
related to the usage.
May there are also some more ideas or aspects to respect for the different variants of the implementation.
Re: Additional code for aPLI Moment Channels
Posted: Tue Oct 17, 2023 10:14 am
... some reference for the compensation factor for the aPLI:
Posted: Tue Oct 17, 2023 10:41 am
This topic will be linked to the topic from Paul:
viewtopic.php?t=697
Posted: Wed Oct 18, 2023 12:00 pm
Based on the discussion at the AK3 Meeting (2023-10-18, VDA) this topic is postponed.
Currently the differences of the two setups are evaluated regarding the realistic differences
in the sensor calibration/sensitivity.
