Additional descriptor for "Lateral velocity"
This topic has been extracted from the discussion of
Additional field descriptors in MME file for active safety
viewtopic.php?t=675
The proposed descriptors for nominal velocity has already been taken over for the "intended velocity"
to the passive safety testing:
Additional descriptor for "Intended Velocity"
viewtopic.php?t=685
In the same way we decided to provide an extension for the lateral velocity of a test object.
The related (optional) descriptor is:
Lat. vel. test object x     :<value>
with
x = tob number
<value> = integer or float value or NOVALUE
This extension will be documented in the next RED A (estimated Q1/2024)
Re: Additional descriptor for "Lateral velocity"
Dear All,
this topic is also related to the new proposal vor RED A:
viewtopic.php?t=718
Here we have also a proposal for the additional velocity information:
A new proposal using the TOB abbreviation could be:
123456789012345678901234567890123
Nominal velocity TOB 1      :
Lateral velocity TOB 1      :
Nom. lateral velocity TOB 1 :
Better readability (less abreviations).
Please vote :-)
I support this idea of this descriptor “lateral velocity” and the shortened “TOB” for the test object.
“TOB” would be a benefit for many new descriptors in ISO MME due to the restriction to 28 characters.
based on the discussion in the meeting today I have summarized the base information and options in the attached PDF:
Options for new velocity descriptors.pdf
(15.25 KiB) Downloaded 525 times
Finally we identified a new topic for "longitudinal velocity" to be found in the proposals and in the CA004 document from EuroNCAP.
Actually, this overlaps with the current "velocity" and "impact side" information in passive safety testing.
I will prepare a separate topic for this discussion soon, but in the active safety sub-board.
