RibEye - Coding of 1D displacement output
Posted: Tue Mar 26, 2024 1:14 pm
in the NHTSA Dummy Qualification documents for the WS the equivalent displacement generated from the RibEye system
as from a 1D MTRAC is used. In the document the code is given with the physical dimension "DS" and the direction "L".
We should discuss this coding and may also the option to have also the same or a similar coding for the
1D MTRAC equivalent from a 2D or 3D MTRAC device.
Kind regrads,
Re: RibEye - Coding of 1D displacement output
Posted: Tue Mar 26, 2024 2:02 pm
extract from the document:
2024-03-26 15_00_33-NHTSA-2019-0108-0006_attachment_1 - PDF-XChange Editor.png
2024-03-26 15_00_33-NHTSA-2019-0108-0006_attachment_1 - PDF-XChange Editor.png (122.72 KiB) Viewed 18745 times
