Database 1.6 Rev 3 Proposal 1 (Snapshot 2024_04_18)
Posted: Fri Apr 19, 2024 11:09 am
to have an intermediate state of the database and the RED B and C, please find here a WIP variant.
01_Version_163_p1_snapshot_2024_04_18.zip
(4.85 MiB) Downloaded 1143 times
RED_B_163_p1_2024_04_18.pdf
(378.63 KiB) Downloaded 1228 times
RED_C_163_p1_2024_04_18.pdf
(2.73 MiB) Downloaded 1184 times
To use the database GUI you will need a 32 bit office.
The internal references to the code database and the figures in the GUI database do reference
the installation path:
„E:\Daten\MMEDB-Test\“
So, if you have the ability to use this location it will be simply to apply the GUI database.
Otherwise you will need to change the references in the GUI Database.
The code database should also be found via a relative path.
The figures path is relevant to generate RED C.
Re: Database 1.6 Rev 3 Proposal 1 (Snapshot 2024_04_18)
Posted: Fri Apr 19, 2024 11:15 am
... some hints for configuring the figures path in the GUI database:
Enter the system dialog:
2024-04-19 13_12_17-ISO-MME Codification Manager.png (47.07 KiB) Viewed 42930 times
change figures path:
2024-04-19 13_11_55-ISO-MME Codification Manager.png (13.97 KiB) Viewed 42930 times
