RED A (1.6.3) Proposal 1
Examples and Hints
Dear All,
please find here the document under discussion for the RED A 2024.
The changes cover the following forum topics:
  • additional descriptor for "lateral velocity" (A.2.1.1)
Lat. vel. test object x :0
Nom. lat. vel. test object x:0
  • LCW row/col and direction information (A.2.2.5)
  • correction in A.2.2.10 for optional ".Sensitivity" descriptor
  • IR-TRACC, MTRAC usage (A.2.2.10)
Dokument:
ISO_TS13499_RED_A_V16Rev3_20240710.zip
(73.31 KiB) Downloaded 3005 times
ISO_TS13499_RED_A_V16Rev3_20240710.pdf
(67.19 KiB) Downloaded 2505 times
Re: RED A (1.6.3) Proposal 1
Dear All,
based on the findings on the Task Force meeting today, I have prepared an updated version of the RED A proposal.
The changes are:
Velocity descriptors (page 8 )
Implemented new namings that uses the abbreviation "TOB" for better readability
and less abbreviated words in the descriptors.
Data Status (page 9)
Allow for status "channel failed" and "system failed" the modification
of the channel samples (may for delivery requirements).
Still the assessment is invalid for these Data Status.
Please find the new proposal here:
ISO_TS13499_RED_A_V16Rev3_20241119.pdf
(66.6 KiB) Downloaded 1911 times
Dear All,
for the discussion I have the following topics related to the Data Status:
  • Sorting of the list from "Good" to "Bad"
  • Is NOVALUE to be treated as "data invalid" or as "ok"?
  • Partially failed should be combined with a valid time range for the analysis (or a list of invalid intervals)
Dear All,
for the Meeting on the 5th of June 2025 please find the latest version of the RED A for discussion.
I have added a Data format section as "A.0" at the start that included a subset from the types of RED A from version 2.
All latest changes are in violet color in the document.
ISO_TS13499_RED_A_V16Rev3_20250604.pdf
(68.64 KiB) Downloaded 1423 times
...please find here the updated document after the meeting 2025-06-05:
ISO_TS13499_RED_A_V16Rev3_20250605.pdf
(67.78 KiB) Downloaded 1539 times
Dear All.
I would like to provide to you the latest state of the working document of RED A:
ISO_TS13499_RED_A_V16Rev3_20260105.pdf
(67.86 KiB) Downloaded 1132 times
So you have the latest status available for the next meeting.
Dear All,
after the meeting with the Active Safety WG today the new velocity descriptors have been
revised:
Please find the complete RED A document proposal with the latest state here:
ISO_TS13499_RED_A_V16Rev3_20260218.pdf
(173.35 KiB) Downloaded 911 times
minor changes in the velocity descriptions has been applied:
RED_A_V16Rev3_20260223 - Velocity Descriptors.png (114.66 KiB) Viewed 70590 times
Final document is now:
ISO_TS13499_RED_A_V16Rev3_20260223.pdf
(67.95 KiB) Downloaded 995 times
Return to “RED A (1.6.x)”
