Nominal velocities
Posted: Thu Oct 10, 2024 2:41 pm
by washausen
Hello everyone,
some time ago we agreed on attributes for nominal velocities of test objects to determine validities:
Nominal vel. test object X
Nom. lat. vel. test object x
For different test scenarios it would be helpfull to have several nominal velocities (e.g. speed limiter, CCRb,...).
Could it be a soulution to allow a list of values like
Nominal vel. test object X :18.889;8.333
Re: Nominal velocities
Posted: Sun Oct 13, 2024 11:10 am
Dear Mr Washausen,
my concern is, that it will not be clear which value belongs to which device without further
information.
Just another idea for the discussion:
Can we use descriptors with "counters" and add the information on the related device?
Like:
Nominal vel. test object Xa:15.050
Some ideas on how to provide additional information on the related device:
A) via a separate descriptor
- several descriptors to transport the combined information
12345789012345678901234567890
Nominal vel. X device :speed limiter
Nominal vel. Xa device :CCRb
B) via an additional text behind the value
- migth interfere with existing import routines.
- will group the information
Nominal vel. test object X :18.889 {speed limiter}
Nominal vel. test object Xa:15.050 {CCRb}
With the parallel discussed idea of changing "test object" to TOB in the descriptor naming
we might also gain some space to have other options?
C) by modifying the descriptor name
- Will group information
- limited space for descriptive device text
Nominal vel. TOB X speedlim:18.889
Nominal vel. TOB Xa CCRb :15.050
