Figures for THOR AV
Posted: Tue Mar 04, 2025 5:30 pm
There is a request from Humanetics to step forward with the coding list of the THOR AV.
In the topic: https://www.iso-mme.org/forum/viewtopic.php?p=1249
we defined the base FL3 code for this kind of dummies.
For the specific variant of Humanetics a channel list and may figures are desired to
support the standardisation in the channel naming for this variant.
Attached you will find a list of the available instrumentation for the THOR AV.
THOR AV Instrumentation list.xlsx
(11.95 KiB) Downloaded 704 times
Re: Figures for THOR AV
Posted: Wed Mar 05, 2025 2:54 pm
by chadivan
Can you confirm that the AV will use TV as the fine location 3? I have started the copy of TH and will update it with the specific sensors.
Posted: Wed Mar 05, 2025 4:48 pm
by chadivan
Attached is a draft for the THOR AV Figure
Posted: Mon Jun 08, 2026 4:37 pm
Please find here the latest list for the preparation of the TV measurement channels for the db and figures:
THOR AV Instrumentation list_ISOMME_IAT_006.xlsx
(270.29 KiB) Downloaded 7 times
One important topic will be the lower leg coding.
As the dummy is based on the classic THOR (TH) it might be using the H3-LowerLegs or
the Advanced legs. The intention is to firstly implement the shared channels of both leg
designs for the TV and await the future need to have the one or the other leg design in regulations.
