Full Width Frontal Deformable Barrier
Posted: Wed Mar 05, 2025 12:07 pm
by radek
we need to define new fine location for the new Full Width Frontal Deformable barrier that Cellbond has published on their website:
https://www.cellbond.com/products/defor ... l-barrier/
The barrier will be used in some tests within EuroNCAP 2026.
I propose following codes for fine location 3: DF, or alternatively DW
Both of codes should be available.
Thank you.
Radek
Re: Full Width Frontal Deformable Barrier
Posted: Wed Mar 05, 2025 4:19 pm
Discussed on the Task Force meeting 2025-03-05:
The coding "DF" will be available and is not used so far in the coding database.
The codings for other defomable element are listed also in the figure:
"Other objects" figure "ISO_OBJ_1_16x.emf" or the RED C.
2020_06_17_ISO_TS13499_RED_C_1_6_2_page_89.pdf
(13.2 KiB) Downloaded 710 times
We might add the coding, but would like to investigate first the usage of the coding
for the defo elements. It is not clear for which kind of measurements the coding is needed.
