Pure Database 1.6 Rev 3 Proposal 1 (Snapshot 2026_03_19)
Access database files
After the task force meeting today I would like to provide the current backend for inspection and
use of the latest extensions of the ISO MME database.
The changes in the 1.6.3p1 so far are:
ML: added EDUN - electric drive unit - elektrische Antriebseinheit
PC: added general code for EDUN
ML: added TEYE - towing eye - Abschleppoese
PC: added TEYE + DS/FO
F1: reworked sorting indizes
F2: reworked sorting indizes
PD: added new derived physical dimension EI - Electrical Isolation with Unit 1/A or typical Ohm/V
F3: changed naming for "TV" to "THOR 50th Dummy ASP-Variant" and for "TW" to "THOR 5th Dummy ASP-Variant"; code explanation now more generalised and with neutral dummy naming
PC: added NIJC variants for TH for different CIV settings
ML: added new main location for active safety with the type "ActiveSafety"
ML: added sortkey for Human Model codes
ML: added DAMC and CBIC for Damage and CIBIC criterion
PC: added channels for DAMC and CIBIC for CVC and result channel
ML: Fixed sortkeys for CLEV
ML: refined the Humans sort codes
MK: fixed some sort codes (LUGG)
F2: added FC for compression (ACTB,TH, NHTSA)
PD: added new physical dimension for Number (NO)
ML: removed mispelled entries for PSAD, PSAF
ML: renamed mispelled entry for PDAP to PDAD
ML: changed PDC3 to PDC2 (existing dummy)
FIG: Figures for BR updated to 2021-07-07
FIG: Figures for WS updated to 2022-09-01
ML: added PEND for usage with dummy certification coding (and elsewhere)
F3: added codes for BioFidel Dummy: FS,FM,FL
F3: added code for MP: "Map of Pressure", pressure map
PD: Added VC  (Volume Concentration) with base unit 1 for Helium and Hydrogenieum
F3: Proposed gas identifier HL = Helium, HY Hydrogenium
F3: added codes to realize HV measurements: R0 = R0 Voltage, CH = Chassis
PC: Added WS DC0 channels
ML: added PEND for dummy qualification coding
PC: Copied TH codes as TV (without NIJC)
PC: removed ABDO MTRAC channels for AV and added ABDOLE/RI PR
PC: removed TV NECK cable forces
FL2: added comments for IN OU to be used also for "in" and "out" direction
FL2: changed naming fro TO from "Total Moment" to "Total" and provided comment to use this code part for Total Moment or for balanced value (sum, difference)
FL1: added A1, A2, S1 S2 for adaptivity periods or stage series for airbag simulation coding
FL1: removed former temporary TH codes for FB=Frontal Bone; MB=Mandibula; MX=Maxilla
FL1: added new code parts for airbag simulation coding  FB, MO,SE,VE
DIR: added "I"  and "O" for airbag simulation coding
FL3: added AV = "Airbag Vehicle" for new Airbag codes
PC: assigned all AIRB codes to the new group "Airbag" (18 records re-assigned)
PC: added new Airbag codes to the new groups "Airbag" and also new group "AirbagSim" (762 records added)
FL2: added seat for codes related to seat but with otherwise used ML (example for simulation: ??MINCSUSE00MA00)
PC: added RF = Rate of Force as to be used for Iliac force drop
please find the mdb file within this archive:
mme_code_Snapshot_2026-03-19.zip
(433.07 KiB) Downloaded 16 times
You can use this database as a replacement for "mme_code.mdb" in the former topic regarding 1.6.3p1.
Return to “Database (1.6.x / 2.x)”
